checking Auto Trans fluid? Changing filter??
Old Aug 23, 2004 | 06:29 PM
Speedtoys's Avatar
Speedtoys
Default checking Auto Trans fluid? Changing filter??
I know this is probably a dumb question, but how do you check the auto trans fluid? When should you have it changed, also how do you change it and the filter? Is it something better left for a professional to do??
Thanks for all your help guys!!!!!!
Old Aug 23, 2004 | 06:55 PM
alanh's Avatar
alanh
Automatic transmissions today are generally serviced by a dealer that has the pumping system to change the fluid. If you remove the pan, you only remove about 1/3 of the fluid, with the other 2/3's stayng in the transmission and torque converter. The pumping system extracts the old oil by pumping new oil in its place, forcing the old oil out.
