160 T stat.. Fan settings?
Old Aug 24, 2004 | 06:08 AM
Fastbasser's Avatar
Fastbasser
Default 160 T stat.. Fan settings?
What is the recommended fan settings when installing a 160 Stat?
Thanks in advance.
Old Aug 24, 2004 | 06:50 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
are you doing it in conjunction with a Hypertech/Predator programmer?? If so it should do it for you.
Old Aug 24, 2004 | 07:18 AM
ArmyVette's Avatar
ArmyVette
I'd like to know these fan settings as well. I have LS1 Edit, not one of the others.
Old Aug 24, 2004 | 08:25 AM
GOOSE JR.'s Avatar
GOOSE JR.
Thanks in advance.
I use the Vinci H.P. fan switch it was set at 170 degrees to turn on the fans, just for a backup I used the Vinci Programmer to set the PCM at 190 degrees to turn on the fans. the motor on a summer day stays about 193 degrees which is about the temperature the stock radiator will support. Gary
Old Aug 24, 2004 | 09:00 AM
6Speeder's Avatar
6Speeder
Fan setting 1: On @ 185, off @ 175. Fan setting 2: On @ 195, off @ 186. Using these settings, mine stays in the 175 to 185 range in the summer, 170 to 180 in the winter.
And no, that's not too cold for the LS1
Old Aug 24, 2004 | 09:12 AM
IMQUIK's Avatar
IMQUIK
Old Aug 24, 2004 | 09:16 PM
Fastbasser's Avatar
Fastbasser
Default Thanks!!
Thanks guys. You have been more than helpful!
To 160 T stat.. Fan settings?
