I was hoping someone could tell me the difference between ZO6 brake calipers and standard C5 Coupe's. Are the ZO6 brakes a direct bolt on? Are there any gains in performance or do they just look Thanks
Direct bolt on, only difference that I am aware of is a different material for the pistons that transfers less heat from the pads into the fluid. So yeah primarily aesthetics.
Identical with the exception of the red paint and the front Z06 brakes come with Hawk pads.
