I am thinking about getting a set of AFR heads on my Z and am curious what kind of torque numbers you guys are seeing witht these heads with big cam like the LG G5x3. I looking for a package with around 450 rw torque. Is this possilbe with just a H/C package.
LGM has made 500+/450 rear wheel, but that was with every bolt on, very good ported LS6 heads (I see you do have many the required ones) and a G5X3 on a 112 lsa.
It will take an aluminum flywheel, 90mm intake, good tuning, and low restriction/3" exhaust, and probably other tricks as well. The AFR's should be able to do the same hopefully, if not better.
