Column lock software fix gave me new high-octane spark table???
Old Aug 27, 2004 | 11:07 AM
SideStep's Avatar
SideStep
Default Column lock software fix gave me new high-octane spark table???
Went this morning to dealer for the Column lock recall. It consisted of checking the physical column lock clearances and a code update to the PCM...
...if you look at the below spreadsheet the 1st tab shows the spark I went in with and the 2nd tab shows the table from the upgrade. I had been trying to return my PCM code to factory (I never had a copy) and I got the table I was using from ls1edit.com. I thought it looked dead-on compared to other 2001s....
The new table is MUCH more conservative...????
High-Octane Spark Table
Old Aug 27, 2004 | 11:22 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
I think there is a TSB about knock, maybe that's why they loaded the lower advance table. Reload the old one!!
Old Aug 27, 2004 | 11:39 AM
SideStep's Avatar
SideStep
I thought the same, but I have not been reading any knock with my HPTuner scanning software.... I think I will combine both and take the high cells from each...
Old Aug 27, 2004 | 01:36 PM
SideStep's Avatar
SideStep
UPDATE: I changed the spreadsheet on the first post to look at both spark tables and build another spark table using the greater value of the two... Feel free to use it if it helps you...
To Column lock software fix gave me new high-octane spark table???
