Shift LIght Install Pics
Old Aug 27, 2004 | 07:49 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Default Shift LIght Install Pics
Here's a couple pics of my shift light I just installed. I used Flyin 'Brian's excellent instructions of connecting it to the tach wire under dash on drivers side.
Decided to mount it in the dual gauge pod pillar like several forum members have done. All that was required was to drill a 3/4" hole in the gauge pod and the shift light fits very nice and snug.
Wiring was also easy after finding the correct white wire to tap as Brian suggests. There's 4 white wires in the bundle and had to go through all 4 before hitting the right one! The correct one was one of the 3 smaller white wires. The larger off-white color wire that Brian used wouldn't work for me.
Entire install only took 1 1/2 hr.
Old Aug 27, 2004 | 08:30 PM
Patches's Avatar
Patches
Excellent work. That is my favorite spot. If only I had a reason to put gauges in. Then I could move mine there.
Old Aug 28, 2004 | 09:59 AM
AllCammedUp's Avatar
AllCammedUp
That is bad-***! Thanks for posting the pic! I now know how I'm going to mount mine!
I'm going to install a PLX WB-02 and a digital/analog gauge in the first pod along with the shift light where you show. I now need something to install in the second pod.... what do you guys suggest for a NA car?
Also - if I can't decide upon another gauge to install, does anyone know where to get a 'blank' filler to close up the hole?
Thanks again!!
[edit] Could you please post a link to his instructions... I've tried searching by username and come up w/ nothing. Thanks again.
Old Aug 28, 2004 | 10:49 AM
Patches's Avatar
Patches
Here you go.
Flyin'Brian's Shift Light Tutorial
Old Aug 28, 2004 | 01:02 PM
AllCammedUp
Thanks!
Old Aug 28, 2004 | 03:29 PM
T_Vert's Avatar
T_Vert
what shift light and what size gauges are those? Whose pod? Wondering how you adjust the shift light activation rpm
dave
Old Aug 28, 2004 | 04:35 PM
AllCammedUp
The shift light is a Harlan. The gauges are 2 1/16", I believe, as it looks like my pod (which is an Autometer dual-gauge). Not sure how it works on other shift lights, but the harlan actually breaks down and has a small IC w/ a row of DIP switches on it that you set for the activation RPM.
Old Aug 28, 2004 | 04:55 PM
T_Vert's Avatar
T_Vert
is this the one?
http://www.raptorperformance.com/
Dvve
Old Aug 28, 2004 | 04:59 PM
AllCammedUp
Wow - I didn't realize the Raptor and the Harlan were so similar. At this point, I really can't tell... lol... it looks just like my Harlan, but the Raptor looks like the Harlan (and vice-versa) as well.
Old Aug 28, 2004 | 08:50 PM
Patches's Avatar
Patches
That's a Raptor pictured above. The Harlan is too big to be mounted like that. Actually, the Raptor is much smaller in diameter than the Harlan. If you remember, I made the custom Harlan brackets. I based them on the Raptor but had to scale them up quite a bit to fit the Harlans. Here's a pic of the Raptor bracket on the left and the custom Harlan I made on the right.
Old Aug 28, 2004 | 09:22 PM
Z06-JIM's Avatar
Z06-JIM
dave
It is an Arizona Nitrous Technology Shift Light. They seem to be identical to the Raptor lights including the adjustment screws & switches.
The light fits in the 3/4" hole very tight but is still fairly easy to slide in and out which allows adjusting RPM settings as needed. Just be sure and leave enough slack wire inside the gauge pod to accommadate this.
The pod is an Autometer Duel Gauge unit with 2 1/16" Autometer Cobalt Gauges.
Here's a link to Arizona Nitrous Technology site"
http://www.nitrous4less.com/
The above link doesn't seem to be working?
If you do a search on Yahoo for "Arizona Nitrous Technology", it will take you right to the site.
Old Aug 28, 2004 | 10:21 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
That looks great!
Old Aug 29, 2004 | 08:15 AM
AllCammedUp
Wow - I didn't realize there was such a difference. I stand corrected.
I really want the clean look of that install, so I'll probably get a raptor and sell my Harlan and mount.
Thanks for the confirmation.
Old Sep 2, 2004 | 08:00 AM
TERMN8R's Avatar
TERMN8R
Quote, "There's 4 white wires in the bundle and had to go through all 4 before hitting the right one!"
Gald I'm not the only one with that kind of luck. Love the Raptor!
Old Oct 4, 2004 | 10:19 PM
J-Rod's Avatar
J-Rod
looks good. Any way to mount a light without having to put a gauge pod in..
Old Oct 5, 2004 | 07:16 AM
Patches's Avatar
Patches
J-Rod, you can use the stock bracket that comes with the Raptor to mount that one. The larger one I designed for the Harlan was a special I did for a coule of buddies. Here's my Raptor mount.
Old Oct 30, 2004 | 04:28 AM
van1's Avatar
van1
Ive been watching this tread...I have to now get the raptor light, and gauge pods. I was wondering, any gauges I might better stay away from. I was thinking Id go with an auto meter electric fuel pressure gauge and Im not sure for the A/F mixture...I guess auto meter also. Anyone else have anyother suggestions. Thanks guys.
Old Oct 30, 2004 | 08:50 AM
GOOSE JR.'s Avatar
GOOSE JR.
Great looking install with the guages. Where did you get the guage holder?
Old Oct 31, 2004 | 03:09 PM
Z06-JIM's Avatar
Z06-JIM
Thanks Jerrod. Yes, the shift light comes with a mounting clip that can be fastened to your stock A-Pillar. I've seen it installed this way and it looks good.
Hope to see you at the Z06 Fest again next year. Can I put in an early request to you to make a couple passes down the track in my car again next year?
To Shift LIght Install Pics
