Using KwikLift for Corsa Tiger Sharks?
Old Sep 1, 2004 | 12:08 PM
LivinTheDream's Avatar
LivinTheDream
Default Using KwikLift for Corsa Tiger Sharks?
Has anyone used their Kwiklift to install Corsa cat backs? I think my friend could use my KL easier and more safely than jack stands. He's cutting the stock exhaust off--I'd hate for him to come over and find it's too low. Thanks--
Old Sep 1, 2004 | 12:35 PM
FreddyG's Avatar
FreddyG
Yes, you could probably use the KL, because I've heard of guys putting them on using jack stands. The KL would allow the car to be raised higher. If you take the swaybar down (loosen the four bolts, for the bushings), you won't have to cut the exhaust off, and could save it, in case you'd need it again. Good Luck!
Old Sep 1, 2004 | 01:36 PM
wrustywrench's Avatar
wrustywrench
kwik lift worked great to install my slp pipes,, I really dont think you will need to cut the old as you may be high enough with the lift. especially if you loosen the sway bar....easy job
Old Sep 1, 2004 | 02:10 PM
LivinTheDream
Thanks guys--appreciate the info!
Old Sep 1, 2004 | 06:19 PM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Yep, You can use the Kwik-Lift I used it to install a Corsa system on my 02 and remove it when I traded it in. You don't need to cut the stock system either. HEB
To Using KwikLift for Corsa Tiger Sharks?
