Clutch problem?
and I notice that the more I stop and go the stiffer the clutch pedal is getting. The shifter also starts to get a little more notchy as well. At the end of the 2 hours in traffic the clutch pedal is HARD. Probably double the stiffness.
Theories on what is going wrong? Master cylinder? Slave cylinder? Does the fluid just need to be changed? Clutch itself?
Thanks,
--Bill
