car reached 228 degrees
Old Sep 5, 2004 | 09:21 AM
tramminc's Avatar
tramminc
Default car reached 228 degrees
while sitting but came down to 215-230
tramminc's Avatar
tramminc
[QUOTE=tramminc]while sitting but came down to 215-230
Old Sep 5, 2004 | 09:31 AM
angryfly's Avatar
angryfly
These cars run that hot it is normal. Mine used to get that hot all the time before I installed a cooler thermostat.
Old Sep 5, 2004 | 09:36 AM
tramminc's Avatar
tramminc
i did install a 160 last week but i guest the car has to be moving
Old Sep 5, 2004 | 09:40 AM
tramminc's Avatar
tramminc
anyone know a tuner in boston/ma. area
Old Sep 5, 2004 | 09:47 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Unless your car is modified don't run a 160 thermostat, thats too cool these engines were engineered to run hotter and running too cool not only causes higher emissions but will stress your engine
Old Sep 5, 2004 | 12:29 PM
simpleman68's Avatar
simpleman68
I hear you about the running hotter than h$!! deal. Mine used to creep up into the 235 territory and that made me nervous until I heard other guys tell me it is normal for a stock set-up.
Changing your T-Stat has minimal effect unless you've programmed your fans to a lower setting. GM has them set to kick in at 235 degrees or when the AC is turned on.
Cartek put in a 160 for me and programmed my fans to kick in at 165.
On days that are between 80-90 degrees, my coolant temp is between 190-195 which is supposed to be optimal for engine performance.
Old Sep 5, 2004 | 08:01 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
All the t-stat does is open the coolant flow valve at a lower temp. Stock is somewhere near 190. The upper temp is normally control by the fans which come on near 230 stock, so those temps in hot, stop and go traffic with little to no airflow through the radiators are normal.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 5, 2004 | 08:03 PM
Monster231's Avatar
Monster231
yep it normal to be in the 230 range. Next time turn on your AC, the fans will kick in and it will help cool you done
Old Sep 5, 2004 | 08:34 PM
Corvette00Car's Avatar
Corvette00Car
I installed an aftermarket Hayden Fan Controller. It was $40 from PepBoys and it works great. Even in DC traffic temperature doesn't go above 200.
Old Sep 6, 2004 | 01:21 AM
Mrhavasu's Avatar
Mrhavasu
Was it a plug in set up? Easy to install? Thanks.
Terry
Old Sep 6, 2004 | 09:30 AM
Corvette00Car
Very easy to install. I know I found the instructions on this forum in one of the posts. If you wish I'd be pleased to e-mail the instructions which I saved. The only confusing part (if you can call it that) is whether you want the fan to continue running after the ingntion is off (default which I choose). That runs the risk of running the batter down. Mine is a daily driver in DC and I've never had a problem. The sensor just pushes between the fins in the lower driver side of the radiator and the relay is in parallel with the power to one of the fans. So if the aftermarket relay fails the stock controls take over. It is also easily adjustable.
Old Sep 6, 2004 | 08:06 PM
Esman1's Avatar
Esman1
3rd Gear
Default higher temperature
mine was running that hot even with the 160 thermostat and the LS1 edit which turned the fans on at a lower temp., MTI ended up changing out the radiator with a used one and now even in a summer in Houston it does not get above 205 and stays around 190 typically which is where they say the LS1 likes to run.
To car reached 228 degrees
