Hurst Install
Old Sep 7, 2004 | 07:24 PM
Calvet01's Avatar
Calvet01
Default Hurst Install
looking for the installation instructions from CF member Patches, but keep getting NOT FOUND Any suggestions? Thanks Jerry
Old Sep 7, 2004 | 07:58 PM
Patches's Avatar
Patches
That web page is hosted by the corvette forum server that went down. Hopefully it'll be back up before the end of the week as Troy indicated in his update.
I do have a PowerPoint version of it but it doesn't contain all the text that the web page does. Email me at edbon@adelphia.net and I'll send it to you if you want it to get started.
There are also a couple of other nice tutorials on it. Hopefully, someone will weigh in with the url's here.
Old Sep 7, 2004 | 10:05 PM
Overtorque's Avatar
Overtorque
I had the same problem this weekend. The server was down so I could not get the directions off the Forum. Instead, I used the instructions for the B&M Short shifter http://www.2phast.com/Corvette/b&m.htm
Install process took approximately two hours. The toughest part was getting the T bracket off the stock shift ****. Once that came off it was a snap. I recommend stuffing work raggs around the shifter once you have the plate removed. It will prevent you from dropping bolts into the tranny tunnel.
Old Sep 8, 2004 | 01:06 PM
Sorny's Avatar
Sorny
It took me about 4 hours to do it following the instructions that come with the Hurst (3 hours to get that blasted demon key, the T-Nut) out. Aside from being afraid to reef on the T-Nut, there is nothing to it. Had I been equippped with the right tools (vice-grips for the demon key, or two small screwdrivers), the job would have been about 1 hour and 5 minutes to complete the job from start to finish.
I'll second the recommendation to stuff rags around the tunnel, I did not and had a real fun time fishing a bolt out of there.
Sorny
To Hurst Install
