Signal light problem
Old Sep 9, 2004 | 12:12 PM
One Blue Vette's Avatar
One Blue Vette
Default Signal light problem
I have an intermitent signal light problem on my 2001.
I have narrowed it down to the hazzard light switch in the dash board.
If I move the hazzard switch around or shim it with a folded business card the signal lights will work.
Has any body had this problem and how hard is it to replace the hazard switch?
Old Sep 9, 2004 | 02:07 PM
DickieC.99's Avatar
DickieC.99
have you ever taken the center dash consol off? sounds like the connection to the hazard switch is not connected fully or is bad. If you havn't maybe taking it off to get a look is a good idea...real simple to do
Old Sep 9, 2004 | 02:17 PM
SteveL2's Avatar
SteveL2
It's not too hard if you do the brute force way, which leaves the dash in place. I posted in a thread about how to do this, and I'll go see if I can find it.
Or, you can pull the whole dash, but that sounded like a bit much for this fellow.
Old Sep 9, 2004 | 02:20 PM
SteveL2's Avatar
SteveL2
Darn it, I found one of the threads, but with the hardware problem here on the forum recently, the pictures are not yet back up. Hopefully they'll be up soon enough.
Go down after a few posts in this thread: http://forums.corvetteforum.com/showthread.php?t=860333
Old Sep 9, 2004 | 05:03 PM
One Blue Vette
Thanks for the information guys.
To Signal light problem
