Ques: Power Steering Flush Procedure?
Old Sep 9, 2004 | 12:29 PM
Garibaldi's Avatar
Garibaldi
Default Ques: Power Steering Flush Procedure?
Greetings:
Can one of you kind souls post the procedure for flushing power steering fluid?
Pictures would be an added bonus.
[Standard GB disclaimer---->] And I have searched the archives, to no avail...
Regards,
Garibaldi
Old Sep 9, 2004 | 12:59 PM
kromberg's Avatar
kromberg
Definately interested in this one.
Keith
Old Sep 9, 2004 | 06:22 PM
Trapper Sean's Avatar
Trapper Sean
I've done the turkey baster exchange on my power steering reservoir a couple of times now, replacing about 1/3-1/2 quart each time with Red Line power steering fluid. The first basting was very dirty, but the second was fairly clean. This leads me to believe that :
1) The turkey baster method does actually remove a significant portion of the total fluid in the system.
and either...
2a) The Red Line synthetic fluid decreases wear/tear.
or...
2b) Initial break-in wear/tear grime and assembly greases are taken out with the first basting, and then wear/tear levels off.
Old Sep 10, 2004 | 03:16 PM
Garibaldi's Avatar
Garibaldi
<<<Snip>>>
I'm sure that will work, although I was hoping that there was a procedure for flushing the entire system. I'd also like to add a filter if there isn't one integral to the reservoir. Gootta be cheaper than a rack or pump.
Regards,
GP
Old Sep 10, 2004 | 05:35 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
To Ques: Power Steering Flush Procedure?
