door sagging?
Old Sep 9, 2004 | 03:11 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default door sagging?
I noticed that the passenger side door on my 98 is sagging. I can fit my thumb between the top of the door and the "B" pillar. the back of the door doesn't sit flush agianst the car either.
what needs to be adjusted?
Old Sep 9, 2004 | 09:05 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Hinge or the hinge may be worn out. They are 50 bucks ea.
Old Sep 10, 2004 | 09:29 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
is this a normal c5 occurance?
Old Sep 10, 2004 | 10:15 PM
John Shiels
Depends how often you use it there are no bushings to replace like old hinges. How often you lube them I guess helps too.
To door sagging?
