tire help
PS: I'm running Z06-size rear tires (Michelin Pilot Sports) 295/35-18s on 18x9.5 rims. Tires have approximately 8k miles with no abnormal wear across the tread.
BTW, go back to TireRack.com and see what tire size they recommend for Z06 wheels.
Tire sizes are numbered in millimeters. A 275/40 is 275mm wide. The 40 means the height is 40% of the width. In this case, 275/25.4 is 10.83" wide x .40 is 4.33" tall x 2 + 18" rim = a tire diameter of 26.66". The Z06 is 295/25.4 =11.61" x .35 = 4.06" tall x 2 + 18" rim = a tire diameter of 26.13". Finally 26.13/26.66 = .98012 - 1 = 1.988%
look at all the different brands and compare the tread width. you'll notice the tread width vary. also look at the rim width measured on. that has an effect on section and tread width.
here's a quick compare
tire brand ----- approved rim - measured rim - sec width - tread width
potenza s0-2A -- 8.5-10.5 -------- 9 --------- 10.6 ----- 9.4
potenza s0-3 --- 10-11 ----------- 9.5 ------- 11.1 ----- 8.5
eagle F1 GS-D3 - 9.5-11 ---------- 10 -------- 11.3 ----- 9.2
yokohama AVS -- 9-11 ------------ 9.5 ------- 11.3 ----- 10.1
when it comes to tires. i look for the ones with the most tread width. that's what touches the ground. all of those are 275/40-18 and the yokohama in this compare has the most tread width.
by each tire on the right side click SPECS. it'll show you all the specs. these specs are from the manufacturer.
THanks
