I just had the FAST 90mm intake & 90mm TB installed, Kooks headers along with 3.90's in the rear. I'm currently running a relatively small 2400 stall Pro-Torque converter. What is the difference in the 2400, 2900 on up to 3500 converter. I know that as the stall speed increases so does slippage or the amount of RPM's necessary to launch the car goes up with the stall.
My car is driven 99% of the time on the street and 1% on the track. Before these mods the car ran like a stock C5 until you punch it then it went like mad. With the new mods just completed, can I stay with the 2400 converter? What would be the pros & cons. I'd like a fast light to light vette. Thanks
I finally got to drive my car lastnight. added 3.90's, PT4000 stall, vararam, LG headers. Boy the car is scary. The 4000 stall is hard to get use to. This isn't my daily driver. I can't give you any ideas on which converter to go with. But have fun and good luck.
Under converted means you have too much gearing and not enough stall to take advantage of the torque to the wheels & acceleration you should be having.
Yes guys can use a stock converter with 3.90 gears, but, give them a tight 3500+ converter, and they will tell you their head pulls back when they hit the gas & their car flys!!!
Trust me, you got 3.90 gears, get at least a 3500 stall with a minimum 2.5 STR. (torque multiplication)
When you say track, are you talking about auto-x or drag strip? For autocross, I'd stick with a lower stall converter in order to maintain more precise throttle control. For the drag strip bigger is nice and the converter Ellis suggested would be a good choice. OTOH, if you want a street racer the low STR Super Yanks are a better option.
If your car is all buttoned up now, I'd suggest driving it for a while and getting a feel for what you like or don't like about it now. That'll help you figure out what, if anything, you're looking for from your converter.
I agree with El, the SS3600 would be a great choice for you. Yank's SS series have a real tight feel to them. Thier SS4000 feels as tight as my SY3500 did. So the 3600 should feel like a average 3000-3200 stall. IMO, I could use my SS4000/3.73 combo for a daily driver, so the SS3200/3.90 combo wouldn't be a problem at all. When are you going to the Doctor's next, I'll try to stop by and I'll let you try my combo.
Should be picking her up Friday afternoon from the Docs. Car is not auto-xed but I would rather have a Viper beater from light to light. How much would 1/4 mile times decrease with a Yank 3500 compared to my PT 2400? Like Topless Texan said, I'd rather have a street racer type setup.
