How many RPM's?
Old Sep 12, 2004 | 02:24 PM
donscheffler's Avatar
donscheffler
Default How many RPM's?
Can you tell me where I can put my rev limiter with my new cam, without damaging the engine?
Where did you put it?
Old Sep 12, 2004 | 02:27 PM
BigBlue's Avatar
BigBlue
Depending on your springs and how far the cam will flow and make power, I'd say anywhere from 6500-6700.
Old Sep 12, 2004 | 02:44 PM
donscheffler
I have Comp Cams 26918 Valve Springs and titanium retainers.
Old Sep 12, 2004 | 04:31 PM
see5's Avatar
see5
There will be many different oppinions here. I run mine @6,700. There is a newer timing chain and dampener to consider before you go too high.
Old Sep 12, 2004 | 05:58 PM
Scubanme's Avatar
Scubanme
I used a little educated guessing when I had my rev limiter set. Since a Z06 red lines at 6,500 and the rev limiter kicks in at 6,800, and the springs that I am using are stiffer than the stock Z06 springs, I figured that it woul be safe to set my rev limiter at 6,800...Oh yeah, I have Z06 heads and the lightweight Z06 2 piece valves also and Ti retainers.
Old Sep 13, 2004 | 05:40 AM
donscheffler
So you think that im on the safe site with 6,500RPM?
To How many RPM's?
