Need some advice..LS6 or Fast 90mm
Sep 12, 2004 | 03:38 PM
Well, long story short 2 weeks ago I had another nitrous backfire. This time it blew the back of the intake off and cracked the top and bottom. So I either can...
Buy a new LS6 intake
or
Switch over to the Fast 90mm and NW 90mm TB
Motor Setup
Forged 346cid 12.25:1
TEA/GTP S2 heads
LG Pro Long tubes
~10.7 - 80s on motor
I am trying to decide if its worth dumping the extra money into the FAST setup....
Sep 12, 2004 | 03:45 PM
I would stick with the LS6 intake or wait for the LS2. What grade of fuel are you running with your 12:25:1 compression motor ?
Mark
Sep 12, 2004 | 04:29 PM
fast
Sep 12, 2004 | 06:05 PM
Cruise-In V Veteran
St. Jude Donor '09
FAST with Nick Williams' 90mm TB.
Sep 12, 2004 | 08:16 PM
If youre still going to run the nitrous do you really want to blow a hole in a 1000 dollar intake or a 300 dollar one?
Sep 12, 2004 | 08:21 PM
But i doubt he'll blow a hole through the FAST. I woudl go with the LS6 though
Sep 12, 2004 | 11:06 PM
How about a third option....
LS2 intake with NW 90mm Tb
Sep 13, 2004 | 05:35 AM
I'm all for getting an upgrade when replacement is necessary, just not sure as to what the chance/frequency of that happening is. If it happens once a year, I'd stick with the LS6. Like once or twice in 4 or 5 years, what the heck, get some extra hp!
I wonder if there is anyway to put a blow-off type valve that would prevent this?
Seeya at the track man!
Sep 13, 2004 | 09:29 AM
Sep 13, 2004 | 12:11 PM
The FAST has a built in provision for a burst plate. The others don't. Easier to replace a disc than a whole manifold.
Sep 13, 2004 | 01:23 PM
Thats the way I'm going for the stroker with NOS.
Sep 13, 2004 | 02:29 PM
Any HP to be had with the FAST & NW TB setup?
Sep 13, 2004 | 03:33 PM
Quote:
i got about 20
Sep 13, 2004 | 04:30 PM
Quote:
Originally Posted by kumar75150
i got about 20
Is that over and above a LS6 Intake and stock TB? Is your MAF stock?
