If you guys had the choice of swapping gears or torque converters, but not both, which would it be and why. I am trying to understand the driveability issues between these two choices. For example how would a small stall/big rear differ from a high stall/low rear & visa versa. It seems that I will stay with my PT 2400 converter & 3.90 rear for now because the car should act more like stock from launch. Any help would be appreciated.
Since you already have the 3.90 rear then I would go with the T/C..maybe a YANK SS3800 or even a YANK Pro Thruster 4000
I'm running a 3.73 / PT4000....Nasty at the track and OK around town. I'll assume you have already invested in a Trango shift kit...If not...What are you waiting for...DO IT!!
Since you have the 3.90s, either the SS3800 or the PT4000 are great convertors, it just depends on your taste. With a higher stall speed, your car will rev higher while you are changing gears. With the 2400 stall you are probably reving to about 2000 between gear changes while driving around town. With one of the above mentioned convertors this would be about 2800 rpms. On the highway it should be the same as what you have now. On the track it will DRASTICALLY help your times.
Since I don't go to the track but once a year, it probably wont matter that I have a lower stall converter. Will the car pull to a higher RPM while on the highway without running out of gas too quickly with my lower stall? In my current setup the car will feel more stock than modified which is my goal in case I want to sell her in the near future. I will drive around for awhile in the current setup and go with a higher stall in the near future if I intend to do alot of drag racing.
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
I've driven a PT 4000 and 3.73s for a long time in my 427 car and it hits off the line like a sledgehammer but if your not concerned about getting the best 1/4 mile times as possible and want to maintain as much of a stock feel on the roads then i say save your $ and be happy with what you got!! If on the other hand your lookig for your car to go 0 to 100 mph by a few tenths faster than it does now and lookig to squeeze as much out of your car as possible from accleration from a standtstill then go with the PT 4000 or Yank SS 3800. It seems from what your saying however you should stay with what you have although a higher would probably not feel much looser to you on the street, as the bigger numeric 3.90 gear helps offset the loose feeling that a higher stall converter give you!!! Hope this helps!!!
For what its worth on my new daily driver 02 A4 coupe i am going to 3.73 gears and staying with the stock converter as i a not looking for the best drag times possible and am more concerned about reliability and not jeopardizing my extended warranty!!!
Don't forget, a high stall converter will also help you from a roll, and on top end.
Then what exactly is the downside to a high stall converter and why would anyone install a low stall converter such as my PT 2400? The way it is being explained to me is that a high stall converter will suffer as you approach top end and is mainly for drag applications from a dead stop.
The converter helps you from a dead stop, and an efficient converter will also help you from a roll, but once the converter locks up, it won't make a difference. Putting a converter in is all about trade offs. When I had my SY3500/3.42/FLP Level IV/B&M cooler put in, it is looser than stock (takes more pedal to get it moving. It feels like a stick shift car slipping the clutch..........until you get on it! Then hold on, cause it moves out)!
Converters also make heat, which kills transmissions, so get a cooler too. It shouldn't make that big of a difference with a smaller converter, but with a bigger one, a cooler should be added to the list of necessary items. Take some rides in cars that have converters, and see how they feel to you. I don't track my car, and really like my converter, but we can't tell you what level of driveability is bearable for you. Good Luck!
It sounds like you have had it explained correctly to you.
Besides the loss of fuel milage they also have another downside, they produce more heat and are a torque mutiplier so the life of your A4 will be shortened considerably.
If your a drag racer or like a lot of street action go for the higher stall.
Frankly IMHO 3.42's and a stock converter are the perfect combo for the street with the stock tires. Since I've added FI and a few other goodies there is no traction anyway off the line.
So I have kept the stock tires for the fuse in the driveline.
A high stall converter WILL increase your top end. It keeps your engine in the powerband the whole time, so your motor won't bog down when you upshift, which is especially important with a large cam. Plus most aftermarket converters weigh significantly less than the stock unit.
I took my first *** bike in a top end race the other night, was a great feeling.
It may increase your trap speed but it definitly will decrease your top speed unless it's locked.
Higher stall speed = slip of the fluid coupling (AKA torque converter).
I do agree with you about the importantance of it with a large cam since they typically lack bottom end tq.
Another issue is the apparent lack of understanding of stall speed.
What is a 2400 RPM stall in one car may not be the same in another, it's all related to engine torque and vehicle weight.
A more correct way to look at converters is the "stall torque ratio" this can be applied from one application to another. Apples to apples, not apples to oranges....
People sometimes get confused about the term "locked". "Locked" should mean "the TCC is engaged and slip is at a minimum." (We'll ignore the fact that it's not exactly "no slip" to simplify things.) When this is true, they're all pretty much the same.
That is distinct from when the converter is unlocked but well above stall ratings where there is no further torque multiplication. They are not all the same. One of the things you're interested in here is the efficiency of the converter. Typically, high stall stall converters are not as efficient as low stall converters, and that's not necessarily a bad thing - think about shift extension. Just one more nuance to picking the right converter.
What I'm trying to figure out is if I line up next to a car equipped like mine except for the converter stall what will happen. If I line up next to a car with a 3500 on up stall converter what will happen? If we're both doing 50 and punch it what will happen? Will they jump out on me and then I will catch up? What advantages are there with my smaller stall converter, if there are any except for tranny life? Assume large 3.90 gears for this example.
