Anyone here have Splitfire plugs?
Old Sep 13, 2004 | 03:06 PM
Joe's Eray's Avatar
Joe's Eray
Default Anyone here have Splitfire plugs?
If so how do you like them?
Old Sep 13, 2004 | 05:23 PM
Ls1Rat's Avatar
Ls1Rat
I tried them along time ago on my C4 but they were junk.
Old Sep 14, 2004 | 01:32 AM
BHP's Avatar
BHP
Forget them, go Iridiums.
Old Sep 14, 2004 | 02:05 AM
Double Aught's Avatar
Double Aught
Old Sep 14, 2004 | 06:01 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
On my old '99, I found that they caused a rough idle. I didn't notice any improvements anywhere. I switched to iridiums and was happy after that.
Old Sep 14, 2004 | 07:41 AM
wrustywrench's Avatar
wrustywrench
splitfire plugs are a friggin joke,,, go with iridiums or tr55......the hype of split fire is wrong. Guess they made big bucks from people that believed them.
Old Sep 14, 2004 | 12:42 PM
Evil_Bob's Avatar
Evil_Bob
I had the Splitfires on a Z28, a long time ago when those plugs first hit the market. I thought they performed better than stock...but then Bosch came out with the Platinum Plus 4, and I found out the Splitfires don't even come close to Bosch. I dumped the Splitfires in a heartbeat and never looked back...
Old Sep 14, 2004 | 01:03 PM
charlietuna's Avatar
charlietuna
Default split fire
Split fire, tornado, or any of the other junk advertised on info TV is junk.
If it wasn't don't you think GM or Ford would just love to jump onboard?? Think of all the money they could save trying to meet fleet mileage, without spending a dime....
Old Sep 14, 2004 | 01:51 PM
wrustywrench
:iagree ..I have a neighbor who has just about every gimmick he can buy to get mileage or power, be it tornado, splitfire, oil aditives, fuel line magnets, carb spacer atomizer screens, .... he must have gained 500 hp and 60 mpg.....
Old Sep 14, 2004 | 02:11 PM
Tino's Avatar
Tino
Default Plugs
Ok, dumb question, what's wrong with the factory plugs? Unless you are introducing nitrous or forced induction of some type, stock plugs are great. I run a 1970 Chevelle with a BB chevy and it runs high 10's straight motor, I have tried a number of plug manufacturer changes in the same heat range and no diff in elapse time and top end speed? This is real life trial and tribulations I am sharing.
Tino
Old Sep 14, 2004 | 04:30 PM
C5XTASY's Avatar
C5XTASY
Great experience with the Plus 4's also. Really smoothed the idle and should last almost forever.
Ed
Old Sep 14, 2004 | 05:34 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Ed
As a note, Bosch plugs, wires and microedge wipers blades are available from AMSOIL via the link to the left or in my signature below.
Preferred Customers can buy products from AMSOIL at about 20% under retail. To sign up, please call 1-800-777-7094 and use reference number 1206638 to credit any sales to my dealership (which benefits this site). Thanks for your support.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 14, 2004 | 06:58 PM
Old Rotor Head's Avatar
Old Rotor Head
"what's wrong with the factory plugs?"
At 20k my idle started getting rough. Pulled the plugs, no easy task, and found 4 of the tabs above the electrodes missing. Went with TR55's and never looked back.
Old Sep 15, 2004 | 02:26 AM
Evil_Bob's Avatar
Evil_Bob
Tino
The electrical charge on a factory plug jumps across the gap at only one connection point. On a Bosch Plus 4 plug, for example, the electrical charge jumps across the gap at four connection points, hence the "Plus 4" name. This provides a more equal "burn" and ignition over the stock plug. Also, one of the good advantages of some of the aftermarket plugs is their presetting at the factory...you don't have to "gap" them or worry about having to "re-gap" them down the road. Also, platinum plugs may have a much higher out-of-pocket purchase price than stock plugs do, but they last a lot, lot longer under all types of road and driving conditions...and less corrosion equals less fouling.
Old Sep 15, 2004 | 07:24 AM
wrustywrench
Ok, correct me if I am wrong,,, if a plug has more than one ground electrode, the spark will still only jump to ONE of them , not more , every time it fires....I have always been told electricy takes the easiest path, not multiple paths. am I wrong??? So , I can see if you have deposits on a ground electode and you have more than one, the juice will find the easiest path, so multiple may have its advantage. I have not seem many race plugs like plus 4 or splitfires..but I have seen some strange ones. I have had great luck with the hot u nippo's to not foul like regular plugs. Yes, I tried split fires and they sucked, I have tried bosch plus 2 and they seem ok,,, but irridiums seem the best and last long time, however in the vette I run tr55 , cause thats what my tuner said,and I can blame him....
Old Sep 15, 2004 | 10:26 AM
Ls1Rat's Avatar
Ls1Rat
TRUE
Old Sep 15, 2004 | 10:43 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
[QUOTE=wrustywrench]Ok, correct me if I am wrong,,, if a plug has more than one ground electrode, the spark will still only jump to ONE of them , not more , every time it fires QUOTE]
and I would think that the additional electrodes would shield the spark, particularily in a WOT situation. I've heard of racers, trying for that last little bit, actually install the plugs in the heads before installation with the electrode away from the combustion center to give more exposure to the spark.
To Anyone here have Splitfire plugs?
Old Sep 15, 2004 | 12:48 PM
BHP's Avatar
BHP
You are correct sir and demostrates that multi-electrode plugs are gimmicks. Remember the JC Whitney Fire Ring plugs?
Old Sep 15, 2004 | 01:04 PM
wwashing's Avatar
wwashing
TRUE
This true. But I've been using the Plus 4s for a couple years with good results. The engine runs great.
I'd say they work as good as any the others suggested.
Old Sep 15, 2004 | 01:09 PM
c54dan's Avatar
c54dan
Its done by more than just racers. Its a fairly common trick called "indexing the plugs". I don't think it gains any power but probably prevents a loss of power due to incomplete burn in some high performance engines.
