Cooling system question
Old Sep 14, 2004 | 10:59 AM
marks99frc's Avatar
marks99frc
Default Cooling system question
I was wondering what the consensus among the educated here was about using “tap-water” vs. “distilled, de-ionized” water in the cooling system?
Two schools of thought I have come across doing a search within the forum;
1) Using tap water will introduce minerals which could corrode the cooling system.
2) Using distilled, de-ionized water will lead to the water wanting to dissolve metals from the cooling system and motor to “stabilize” itself into its natural state (where water normally contains such minerals).
While I am no expert it appears that using clean tap water (not from a well but rather community water supply) would be the most logical approach. What are your opinions?
Old Sep 14, 2004 | 12:07 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
You can buy DEXCOOL in a pre mix version....and save yourself the headache
Old Sep 14, 2004 | 12:21 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
But if you mix your own, distilled water is best, because the Dexcool has corrosion inhibitors. Tap water has minerals which can leave deposits.
Old Sep 14, 2004 | 01:00 PM
marks99frc's Avatar
marks99frc
Thanks for the responses, my concern with using distilled water is the chance that it causes the metal within the cooling system and/or engine to actually get pitted (dissolve).
I wasn't aware you could get the Dexcool in a pre-mix, sounds like a great way to go.
Old Sep 14, 2004 | 02:11 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ______________
I didn't know that "distilled" water had an element in it that is capable of corrosion.
Old Sep 16, 2004 | 12:22 PM
bradfordjr's Avatar
bradfordjr
I use Evans' Waterless Coolant...works great and lowered my temps 30* when combined with their new LS1 High-Flow Water Pump.
Old Sep 16, 2004 | 01:21 PM
marks99frc's Avatar
marks99frc
After digging into this deeper I've come to the conclusion that worrying about using distilled water is crazy. I don't know where I originally read that using distilled / de-ionized water will attack metal but it just doesn't appear that it would be a problem here.
To Cooling system question
