When a cam is installed, do they work down throug hteh engine (remove manifold, then heads, etc...) or do they have to remove the radiator etc... and then be able to work on the engine?
just curious
Actually, the heads need to come off to get to the lifters but not to the cam. The heads and intake can stay on for a cam-only swap though. You do, however, need to pull the rockers and pushrods to hold the lifters up to keep them from dropping when you pull the cam. Got to http://ls1howto.com/index.php?articl...be3d7e9f70e05f and check out the cam/spring swap on an f-body. It's virtually the same on a C5.
i just did a cam swap if u have any question jus email me @ rwdrakejd@aol.com if u do a cam swap remember to replace your balancer bolt they are one time use. mine back out twice! just replaced it hope the new one work this time.
