Steering feels weird and c1281 code
Old Sep 14, 2004 | 08:18 PM
Kokopelli's Avatar
Kokopelli
Default Steering feels weird and c1281 code
OK something is up with the front end of my 98 a4 vert, front suspension/steering and I could really use some help. Here are the symptoms: throwing a C1281 code, steering wheel shimmy at 73-80 mph, steering feels mushy when initially entering a fairly hard turn and then seems to tighten up about halfway through, it may be my imagination but it seems like I have more body roll than usual on hard turns. Jacked the front end up to see if I could see anything obvious and noticed some increased inner tire wear especially on the pass. side. I'd greatly appreciate any help - advice - direction anyone might have. Suspension is stock. TIA
Old Sep 16, 2004 | 12:27 PM
Kokopelli's Avatar
Kokopelli
Anyone with any suggestions.....please?
Old Sep 16, 2004 | 12:54 PM
Jeff Jeff's Avatar
Jeff Jeff
The 1281 code is your steering position sensor going bad. I have instructions to replace it that I will email you if you PM me your email address.
Old Sep 20, 2004 | 07:29 PM
Kokopelli's Avatar
Kokopelli
Thanks Jeff. Sent you a PM.
To Steering feels weird and c1281 code
