coolant by-pass kit - a good idea?
Old Sep 17, 2004 | 02:52 PM
Bullet's Avatar
Bullet
Default coolant by-pass kit - a good idea?
I saw this kit for sale.
The factory set-up routes heated coolant through throttle body. This installed tube direct connects coolant lines.
Why did the factory do this in the first place?
Is this a worth while mod?
Old Sep 17, 2004 | 02:57 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
For cold startups in areas with cold winters, to prevent icing of the throttle body.
If by "worth while" you mean "placebo," then yes. But in reality, no, the warmer throttle body does not heat the air enough to rob you of any significant HP. So the bypass is just for people who want to say they've done a mod, but don't want to do anything complicated. IMHO YMMV
Old Sep 17, 2004 | 05:18 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Good Idea? Yeah it will help the economy.
either the kit will put 20 bucks into the economy, or 3 dollars at home depot for the same stuff will help...
Old Sep 17, 2004 | 08:32 PM
George8211's Avatar
George8211
Trottle By-pass kit: Thumbs down
Nothing to be gained here... Go see a show with the money instead.
Old Sep 17, 2004 | 08:47 PM
warren s's Avatar
warren s
Check my website , under simple C5 mods. Its about 2 bucks for a piece of hose, if you want to do it.
Old Sep 17, 2004 | 10:03 PM
C5inWV's Avatar
C5inWV
Simple, inexpensive with regular hardware store hose/clamps.
I did it for a couple of seasons, found it made no difference in performance.
If you switch back to allowing the coolant to warm the throttle body in the winter, you run the risk of screwing something up with the repeated efforts. You know, like cutting a hose or breaking something.
Not worth the effort.
Old Sep 17, 2004 | 11:21 PM
lvvette777's Avatar
lvvette777
I almost did this mod too, I'm glad I saw this thread.
It just goes to show merchants will put "gain 5hp" on just about anything.
I'm sure the high performance hood seal should gain about 20hp by itself right??
Old Sep 18, 2004 | 12:12 AM
MUKAK's Avatar
MUKAK
I'm sure the high performance hood seal should gain about 20hp by itself right??[/QUOTE]
NO U WILL GAIN somewhere in between 10-15 RWHP if u do the COOLANT BYPASS and a HOOD SEAL depending on ur mods
Old Sep 18, 2004 | 07:28 AM
Dark-Knight's Avatar
Dark-Knight
Waste of time and money.
Old Sep 18, 2004 | 12:30 PM
YO-EL's Avatar
YO-EL
I'll disagree....
It took me 4 yrs to do this mod, and I am glad I did....
I can not vouch for increased performance or with dyno numbers, but I do think throttle response it a littler crisper/better, and I DO think cooler air is entering the intake.
Before the mod, I drove my car for 30 minutes, before doing the mod, but I felt the top of the throttle body, and it was fire hot...
After doing the mod, I drove the 30 minutes back home, felt the top of the throttle body, and it was LUKE cool!
I couldn't believe it, before the mod, I could barely put my finger on the TB it was so hot, and after the mod, it was like luke cool...
I started to think, and realized this was a pretty good thing to do. Everyone says the air flows thu the TB so fast it won't pick up any heat, but in my field of HVAC, we insulate exterior duct work so air moving thru it won't absorb heat.
I think its worth doing. Feel the TB, if you don't have the mod. I'll bet its HOT. Do the mod and then feel it....
Cooler air into the intake is better...
Mine stays...
Old Sep 18, 2004 | 01:24 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
yeah forget that mod. get a heads and cam setup instead.
Old Sep 18, 2004 | 01:35 PM
Evil-Twin's Avatar
Evil-Twin
Originally Posted by YO-EL
I'll disagree....
Mine stays...
@ 10 cubic feet a second, air doesnt have any time to heat up or cool down.. the theory is if you can drop the intake air temp by 10 degrees you will get 1.3 horse power increase. The throttle body even without the coolant water circulating through it will be 120/130 degrees passivelythrough engine convection . If your coolant is circulating through it the air will be 180 /190 . The difference between the two is 60 degrees...If the air coming in is 90 degrees, in order to lower that temp to 80 degrees to gain 1 hp, you will need to drop that temp 10 degrees in less than a second. You couldnt drop that temp 1 degree in a second. The air is not in the throttle body long enough to exchange any heat @ 600/700 cfm.
Old Sep 18, 2004 | 07:28 PM
YO-EL's Avatar
YO-EL
Your post it too technical for me...
I'll put it another way, weather your calculations apply or not...
Even though the TB is only a few inches long, I'd rather the air pass thru a luke cool TB, than a fire hot one.
Old Sep 18, 2004 | 10:32 PM
Evil-Twin's Avatar
Evil-Twin
when your throttle body sticks in the open position this winter. ON that one day it looks so nice and you forgot the bypass was in.. Here in Philly it can get cold enough to stick the throttle body. And like I said whether the throttle body is at 190 or 130, it wont make any difference horse power wise, but could potentially cause you some serious damage. And in the wwinter when your car feels really ballsey because your sucking in 30 degree dense air... It will still feel ballsey because the throttle body wont heat it up any either.. thats why your car feels so much stronger in the winter.. 90 degree day vs a 30 degree day represents almost 8 hp gain.. enough to feel the difference.
Old Sep 18, 2004 | 10:46 PM
George8211's Avatar
George8211
Originally Posted by Evil-Twin
@ 10 cubic feet a second, air doesnt have any time to heat up or cool down.. the theory is if you can drop the intake air temp by 10 degrees you will get 1.3 horse power increase. The throttle body even without the coolant water circulating through it will be 120/130 degrees passivelythrough engine convection .....to gain 1 hp, you will need to drop that temp 10 degrees in less than a second. You couldnt drop that temp 1 degree in a second. The air is not in the throttle body long enough to exchange any heat @ 600/700 cfm.
Old Sep 19, 2004 | 12:41 AM
GettReal's Avatar
GettReal
god...cant believe I got "talked into " buying this... I was SO naive when I got my car, i actually didnt know about the forum and went by one of the vendors catalogs and then the salesguy saying what a cheap mod for a few hp....ugh...good thing I dont drive it in the winter
Old Sep 19, 2004 | 01:09 AM
George8211's Avatar
George8211
Me too... But now I know better. I removed mine and it is sitting on a shelf in the garage. There was absolutly no differance in 1/4 mile times. Besides, I did not like how close it was to the drive belts on the engine. If you want more power, save up the pay checks and add a bunch all at once. Maybe a head cam kit.
To coolant by-pass kit - a good idea?
Old Sep 19, 2004 | 07:56 AM
3318C5's Avatar
3318C5
I agree with what most have said, I did this on an LS1 powered camaro and saw no difference. I will not be doing this to the vette.......I'll buy a good steak for the $20.00........
Old Sep 19, 2004 | 08:11 AM
YO-EL's Avatar
YO-EL
No problem you guys..
I just wanted to give you my take on why after 4 years I finally did it..
Beyond that, I have NEVER heard of a TB "sticking" in cold weather.
Everyone talks about it, but 5 yrs here on this forum, LS1.com & LS1Tech.com, I have NEVER heard of this happening...
Old Sep 19, 2004 | 01:18 PM
George8211's Avatar
George8211
I never heard of one sticking either... I heard it was an emmision issue in cold weather and it made some sort of small difference in essimission by keeping the throttle bottle from icing up.
