I can feel it in the shifter and in my feet/butt. Anyone have any clue what it could be? I dont notice it on accel but I do notice it when reving in neutral. Clutch in or out doesnt matter. Any in put is appreciated.
nothing exhaust wise has been touched. why would it occur all the sudden?
Dave
loose clamp, heat, settling, speed bump?? After my header and exhaust install I had the same symtoms and it turned out to be a pipe that was too close to the fuel tank shield. Its free and would only take a second to check.
Look again. Check the flanges where the over the axle pipes connect to the h-pipe section. The welds here are known to be bad on many Vettes.
You won't be able to tell the weld is broken just by looking. It'll LOOK like a perfect weld. Reach up there and shake the pipe and see if the pipe moves in the flange.
