Any adjustment as plug wires keep melting?
Old Sep 18, 2004 | 10:09 AM
JerriVette's Avatar
JerriVette
Default Any adjustment as plug wires keep melting?
I was wondering if there is any adjustment for the spark plug wires ...ie. Coil packs moved an 1/8 of an inch? headers on manifold or bolt to bellhousing??
I have heat soxs on and even with them the wires keep melting? Tried both Taylor or stock wires ?
I only need to shift the drivers side spark plug wire nearest the fire wall a quarter of an inch as it keeps melting as its resting on the header tube and melting..?
Any suggestions would be appreciated?
Old Sep 18, 2004 | 10:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
What kinda headers?? And my MSD's set kinda close to my headers but never a problem
Old Sep 18, 2004 | 10:30 AM
JerriVette's Avatar
JerriVette
The drivers side spark plug wire is touching the header and even with the heat sox they are melting..
Is there an adjustment on some portion of the installation that might rectify wire from melting..?
Right now I replaced the wire again..and took off the heat sox this last time and replaced with metal spark plug protector, because I replaced yet with another spark plug wire ( with heat sox's on I toasted the rear most spark plug wire) and am trying the metal spark plug protector with a new wire temporarily..
I could use advice on how to slightly alter the position of the last spark plug wire so its not so close or laying against the rear most header pipe on the drivers side..and melting..
Old Sep 18, 2004 | 10:47 AM
pewter99's Avatar
pewter99
Well short of flip flopping the wire...on the MSD wires the boot is longer on the plug end than the coil end...the coil packs are pretty much set unless you try and drill new holes to shift them..can you tie the wire off to something?? Do you have a pic of the situation to make this a little easier...
Old Sep 18, 2004 | 12:06 PM
Jeff Jeff's Avatar
Jeff Jeff
Try the stock wires with the stock metal heat shields if you haven't already.
What kind of headers do you have?
Old Sep 18, 2004 | 01:37 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
They sell heat boots for ignition wires.. go to a speed shop. The are fiberglass sleeves that slide over the wires.
Old Sep 18, 2004 | 01:53 PM
pewter99's Avatar
pewter99
he said that it didn't help....I can't imagine what he has going on
Old Sep 18, 2004 | 04:32 PM
USA-VET's Avatar
USA-VET
take a heat gun and shoot your headers to see what temp they get 2!
Old Sep 18, 2004 | 04:35 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Out of curiosity, what kind of headers?
Old Sep 18, 2004 | 09:17 PM
Bob Chapman's Avatar
Bob Chapman
Use the stock metal heat shields.
Old Sep 19, 2004 | 12:15 AM
Scubanme's Avatar
Scubanme
I wrapped my headers and they actually can be touched for a brief moment. They are ceramic coated, so that helps a bit. You could remove the header and dimple them at the spot that it touches the spark plug boot. A medium ball peen works wonders. Just be careful not to crack any welds on the flange.
Old Sep 19, 2004 | 06:30 AM
blktie8's Avatar
blktie8
Default Magnecor
Call Steve at magnecor
www.magnecor.com
Old Sep 19, 2004 | 08:38 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have been running headers with cool socks for years and never had a problem. My headers get 500 to 700 deg at an idle. Are you sure that your tuning isnt way off creating a lean condition? that would really heat up the headers and melt the wires.
VR
To Any adjustment as plug wires keep melting?
By Michael S. Palmer | 2026-06-03 09:39:05
