Fan Operation Question - Not Temp Question
Old Sep 19, 2004 | 03:30 PM
MrLeadFoot's Avatar
MrLeadFoot
Default Fan Operation Question - Not Temp Question
I just wanted some clarification on the way the fans operate. I heard that under a certain vehicle speed they come on based on your temp settings. Is that true? In other words, regardless of the temp settings, do they turn themselves off at a certain vehicle speed?
Old Sep 19, 2004 | 03:33 PM
RoadRebel's Avatar
RoadRebel
The only fan controls are based on engine coolant temp. The only other condition is defrost/A/C..
Phil
Old Sep 19, 2004 | 07:20 PM
gpflepsen's Avatar
gpflepsen
Cruise-In II Veteran
Phil
Thay will both be off, both run low speed (wired in series) or both run high speed (wired in parallel).
Old Sep 19, 2004 | 07:48 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
These are the stock programing commands :
Depends on the model year...
For later model years:
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
For early model years:
Low speed fans come on at 219,high speed fans come on at 228,low speed with a/c on...
Old Sep 20, 2004 | 12:03 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks for the post. So, I guess if my car's running at 178, and my 1st fan is set to come on at 178, then the 1st fan will stay on even at 100mph? Is there a disadvantage to that?
Old Sep 20, 2004 | 01:42 PM
Evil-Twin's Avatar
Evil-Twin
the fans are designed to cycle, not run constantly.. you will wind up replacing them prematurely if you run them constantly..
if your car is running at 100 mph and your coolant is at 178, because of your stat, yes your fans will stay on..
Old Sep 20, 2004 | 01:45 PM
Evil-Twin's Avatar
Evil-Twin
if your car is running at 100 mph and your coolant is at 178, because of your stat, yes your fans will stay on.. if set to come on at 178. with a 178 stat your fans should be set to come on at 190 and off at 183
To Fan Operation Question - Not Temp Question
