Spark Plug Change: Need an Instant Answer
Old Sep 19, 2004 | 05:00 PM
Garibaldi's Avatar
Garibaldi
Default Spark Plug Change: Need an Instant Answer
Greets:
So I'm replacing the plugs in my '00 FRC. I get to #7, pull the wire out and remove the plug. Everything is super fine except there's a rubber o-ring on the porcelain insulator of the plug. Nice snug fit, about .25" thick, outside diameter about the same as the metal body of the plug, inside diameter the same as the insulator. This is the fourth plug I've R & R'd and I haven't seen one of these. I checked the plugwrench and there's a rubber ring inside it.
It's hard to believe that only one plug would have this o-ring. So:
a) is it supposed to be there?
b) there is no b, I guess.
I'll move on to other plugs, hoping to get a quick response.
Thanks,
Garibaldi
Old Sep 19, 2004 | 05:19 PM
Jim D's Avatar
Jim D
No O ring , when I changed mine , must be from socket, # 7 is a pita, good luck Jim
Old Sep 19, 2004 | 05:33 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
sounds like someone left the ring on the #7 at last plug change.
Old Sep 19, 2004 | 05:39 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Ditto - not supposed to be there, so don't worry and good luck. If you think they are hard on a C5 you should have tried #5 & #7 on my Firebird with the LS1!
Old Sep 19, 2004 | 06:39 PM
Garibaldi's Avatar
Garibaldi
Thanks, Guys!
It was a stray O-ring from my Pep Boys Mekkanix Speshul sparkplug wrench. Fixed that sucker with some gorilla snot.
I don't envy F-body guys, but since we're doin' poor me: On a Sunbeam Tiger, the back two plugs were taken out from inside the car! There were two rubber bungs in the firewall...
Thanks again,
Garibaldi
Old Sep 19, 2004 | 06:43 PM
Mike Mercury's Avatar
Mike Mercury
Old Sep 19, 2004 | 08:25 PM
allanlaw's Avatar
allanlaw
A really long time ago, I had a Rolls Royce Silver Cloud II, and if I remember correctly, some of the spark plugs were accessed by removing a panel in the wheel well
To Spark Plug Change: Need an Instant Answer
