Another lowering Question....
Old Sep 20, 2004 | 02:02 AM
TSL812's Avatar
TSL812
Default Another lowering Question....
I know this subject has been beat to death, but hopefully someone can help a little. I did a search and read the "tech tip" already.
The problem is that i cant get the bolts on the front to move. I jacked the spring up, tried an impact gun, braker bar and nothing. I sprayed some wd40 on there and am going to give it another try tomorrow. Anyone else have this problem or have any tips or suggestions?
Thanks,
Tim
Old Sep 20, 2004 | 02:32 AM
posvaldik001's Avatar
posvaldik001
I had this problem as well, I sprayed WD40 from the top and bottom to my heart's desire and let it soak....hopefully that will do the trick for you.
Good luck!
Old Sep 20, 2004 | 02:47 PM
TSL812's Avatar
TSL812
Thanks, I sprayed it down with wd40 and let it soak overnight. Hopefully I will havae better luck when I try again tonight.
Tim
To Another lowering Question....
