Brake Warning Idiot Lite On?
Old Sep 21, 2004 | 07:55 AM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default Brake Warning Idiot Lite On?
After painting my calipers & aftermarket rotors, the idiot lite has come on. Anyone know what the problem is and how to solve it?
Old Sep 23, 2004 | 09:30 AM
Steve02C5's Avatar
Steve02C5
I haven't posted in the TECH section for quite sometime and it looks like we've lost all our "real" Vette tech-types to other forums. It's a shame a member can post a question such as mine and not get a single hit - what's this section coming too?
Old Sep 23, 2004 | 09:58 AM
USA-VET's Avatar
USA-VET
Spray them down with some brake cleaner, then disconect the negative batery terminal for a couple minutes and wala!
BTW, you post at 0300am and want a reply in minutes
Old Sep 23, 2004 | 11:07 AM
Richin Chicago's Avatar
Richin Chicago
Same first question, as always when warnings come on. Have you run the DIC codes? http://www.c5forum.com/ayc/dtcdic.php
When you bled the brakes, did you have the ignition on? If you did and the system sees an "empty brake pedal" it will trhow a code. But now any codes should have an "H" suffix but not a "C"
How do the brakes feels?
Old Sep 23, 2004 | 11:44 AM
Steve02C5's Avatar
Steve02C5
Many thanks U-V, I'll try that.
BTW, I originally posted on the 21st of SEP at 6:55 am.
Richin...No DIC codes and I spray painted the calipers/rotors on the car so there are no brake line issues. Initially the overspray on the rotor pad-surface caused slippage when the brakes were applied until it burned off the rotor and they stop great now. I think the slippage caused the lite to come on, but I don't know if this because a sensor sensed the slippage, or if the paint got on something creating the lite. Thanks for responding.
To Brake Warning Idiot Lite On?
