cam choice?
Old Sep 22, 2004 | 09:01 AM
donnyonee's Avatar
donnyonee
Default cam choice?
im thinking of doing a cam change.
what would be a better choice for my 99 c5 AUTO? a GM ls6 "hot" cam or a z06 cam?
i've got harland sharp 1.8's, b/b shorties, ls6 intake, underdrive pulleys, maf, blackwing, iridiums. im not looking for any speed records, just want a little more. HAS TO PASS SMOG.
thanks, don
Old Sep 22, 2004 | 09:06 AM
C5JONNY's Avatar
C5JONNY
Do a search on cams and see what you come up with. I think some of the custom grind stealth cams tuners are offering will give you a bit more punch than the two choices you have listed and in some states will still pass smog testing with a good tune. The tune is key though. Good Luck
Edit, Also I just noticed your headers, any cam you choose would definitely benefit from a set of long tubes instead of those shorties.
Old Sep 22, 2004 | 11:56 AM
CR555's Avatar
CR555
In order to pass emissions, the cam has to have an LSA of at least 114°. Intake/exhaust duration should not exceed 224°. Since you're running 1.8 rockers, go for a cam with a moderate lift.
These are your options:
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
Comp Cams (Thunder Racing)
212 / 218 .522 / .529 114 LSA 1200-6000 RPM
216 / 220 .525 / .532 114 LSA 1300-6300 RPM
Comp Cams "blower cam" (T Byrne Motorsports)
214 / 224 .525 / .532 114 LSA
218 / 224 .527 / .534 114 LSA 1600-6500 RPM
The GM Hot Cam is not an option for you, since exhaust duration exceeds 224°, and since it has an LSA of only 112°:
218/227 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
112 LSA
EDIT: T Byrne does not sell the Comp Cams "blower cam" anymore...
Old Sep 22, 2004 | 05:43 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
get the MTI stealth I cam!
To cam choice?
