Anyone have this happen??
Old Sep 22, 2004 | 04:58 PM
patrickboyle's Avatar
patrickboyle
Default Anyone have this happen??
I pulled the Vette out for a ride this afternoon as it's really nice outside. While driving back to work the HUD was all messed up & kept fading in & out. I turned it off for a while & then back on & all was fine?? car has been under the car cover for 3 weeks or so..It's an 03 with 3000 miles on it, any idea's ??
Old Sep 22, 2004 | 05:08 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Yeap, this has happened to me a few times, but then it goes away...just another electric problem with the vette...I bet it's either got a short in it,,or a lose connection. I haven't had the time or patience to check it out with my local stealership yet.
Old Sep 22, 2004 | 05:25 PM
patrickboyle
Great, I have no plans of letting the dealer touch my car as they usually wreck more than they fix (looking back at when my Yukon was worked on) Anyway, I guess I'll just keep an eye on it.
Old Sep 22, 2004 | 07:20 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
You weren't wearing sunglasses, were you?
Old Sep 22, 2004 | 07:45 PM
Scubanme's Avatar
Scubanme
check the ground wire in back of the drivers side cylinder head. Make sure to check that on a semi-regular basis.
Old Sep 22, 2004 | 08:55 PM
msghuff's Avatar
msghuff
Me and a friend who also has the HUD both had something simular happen......it was the sun reflecting off the unit. If it hits just right, it will look like its half faded or completly lit up ect. I am embarresed to say since I am a mechanic, but it took me a little while to figure out what was going on and I too thought my unit was broken. Two days later I got a call from my friend who thought his was going bad....turned out to be the sun also. Hope thats your problem becouse those things look expensive!
Old Sep 22, 2004 | 08:57 PM
ZO6vettepilot's Avatar
ZO6vettepilot
It's the sunlight energizing the LED crystals, nothing wrong with the electronics, just one of those things that will occasionally happen under the right lighting conditions.
zo6vettepilot
Old Sep 22, 2004 | 08:58 PM
birch64's Avatar
birch64
mine was the sun hitting at the right angle making it look lighter
Old Sep 23, 2004 | 12:50 AM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Happened to me today and when I moved in the car the sunlight stopped reflecting and when I moved back there went the display
Old Sep 23, 2004 | 12:15 PM
patrickboyle
Thanks for the infor. I will check the ground...but sounds like the sun screwed it up..
Old Sep 23, 2004 | 12:33 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
To Anyone have this happen??
