Which double timing chain doesn't require........
Old Sep 24, 2004 | 04:00 PM
ragtopws6's Avatar
ragtopws6
Default Which double timing chain doesn't require........
mod to the balancer for alignment due to the spacer?
Old Sep 24, 2004 | 04:39 PM
KCZ's Avatar
KCZ
I just installed a Rollmaster Dual Row Adjustable Timing Chain/Gear Set and a ASP Underdrive Pulley and did not have any issues with getting everything to line up.
No machining or spacers required.
Steve
Old Sep 24, 2004 | 04:52 PM
90 droptop's Avatar
90 droptop
Wait until you install a SLP high flow oil pump.....
Old Sep 24, 2004 | 05:06 PM
ragtopws6's Avatar
ragtopws6
I have the ASP pulley. Looks like Rollmaster............
Old Sep 24, 2004 | 05:25 PM
cyclerage23's Avatar
cyclerage23
What wrong with th SLP oil pump?
Old Sep 24, 2004 | 06:11 PM
jamesge's Avatar
jamesge
I have a Rollmaster double roller, TSP ported LS6 pump, and new stock balancer. No alignment problems here.
Old Sep 24, 2004 | 08:40 PM
see5's Avatar
see5
The new LS2 chain is much heavier and dampner is available. I posted pics.
http://forums.corvetteforum.com/show...t=timing+chain
Old Sep 24, 2004 | 08:52 PM
dvandentop's Avatar
dvandentop
see5, what is the cost on those items? I am doing cam install soon
also part #'s
Old Sep 24, 2004 | 09:01 PM
see5's Avatar
see5
also part #'s
CATEGORY: Belt or Chain, Engine Timing
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $107.10
OUR PRICE: $74.97
DESCRIPTION: CHAIN
From the 2004 GM Performance Parts Catalog: page 106:
88958607 Timing Chain Damper, LS1, LS6
“This timing chain damper is intended for high engine speed applications and is used to improve timing chain life. Some blocks require drilling and tapping- an instruction sheet is included. “
GM PART # 88958607
DESCRIPTION: DAMPENER
GM LIST: $117.30
OUR PRICE: $82.11
Old Sep 24, 2004 | 09:48 PM
Scubanme's Avatar
Scubanme
Steve
No machining for the Rollmaster and it is a very nice looking piece of work.
Old Sep 24, 2004 | 09:58 PM
dvandentop's Avatar
dvandentop
see5
is that cheaper then a rollmaster i wonder??
Old Sep 25, 2004 | 06:47 AM
rwj383's Avatar
rwj383
see5
Rollmaster can be found on several vendor sites for <$100. When used with stock balancer, no issues with stock fitment/alignment. Now, if you acquire an older generation ASP pulley with a no recessed shoulder on the outer diameter on the inboard end of the hub, it will need machined to clear the oil pump bolts/shims in order to snug up the the face of the crank timing gear. If a newer generation ASP, it will have the shouldered outer diameter on the inboard end as needed to mimic the stock pulley, thus fitting properly with double rollers without any machine work required. Lou (LGM) and I figured this out together some 6 months back (and 2 needlessly machined pulley's later!).
Robert
www.gen3motorsports.com
Old Sep 25, 2004 | 06:56 AM
ragtopws6's Avatar
ragtopws6
Robert
Thanks, I think my ASP pully is the newer style.
To Which double timing chain doesn't require........
