Rearend noise?? Maybe
Old Sep 26, 2004 | 10:23 AM
vetteman012002's Avatar
vetteman012002
Default Rearend noise?? Maybe
Well I need some help guys, I just installed a new rear yesterday, make that for the 3rd time, and 2 hours after having it in I start to hear a really bad whine, so im wondering what in the hell is going on could it be something else other than the rear. It only makes the whining noise when there is a load on the rear like when I hit the gas, if I dont hit the gas then it doen not make the noise....Any help would be greatly appreciated.
Kevin
Old Sep 26, 2004 | 12:40 PM
RoadRebel's Avatar
RoadRebel
sounds like the ring gear setup
is this a new gear?
has it whined all the time? or was it quiet at first then got loud?
Old Sep 26, 2004 | 10:57 PM
Steve Row's Avatar
Steve Row
Cruise-In II Veteran
Cruise-In III Veteran
Definitely the rear. Had that whine in my rear, but could not believe it was the rear. I've blown rears before, and any whine was on deceleration. But the vette is set up different. The whine is on acceleration.
Good luck.
Old Sep 27, 2004 | 11:37 AM
phear_this_mind's Avatar
phear_this_mind
Had the same problem. Whine on accleration = gears are screwed.
Old Sep 27, 2004 | 12:08 PM
Nick Williams's Avatar
Nick Williams
What are you doing for a break-in? Do you vary the speed for the first little while and do a couple of heat cycles? What type of oil?
Old Sep 27, 2004 | 12:22 PM
Mr. Jones's Avatar
Mr. Jones
sounds like the whine is gear setup. accel/decel one will whine when the gears are matted to the outside of the ring gear and the other when the gears are matted to the inside. I can't remember which.
heat cycle is important with new gears. short easy drive to full temp then let them cool completely. then repeat. 150 mi easy driv'in a must, works for me. the gear manufacture should have a break in method. I have herd complaint about Richmond gears being noisy in other applications, don't know what you are running.
Old Sep 27, 2004 | 12:49 PM
DSimonini's Avatar
DSimonini
I waited 500+ miles on mine before stomping on it. You also have to be careful not to accelerate too hard while turning. This is supposed to be very bad for new gears.
Old Sep 28, 2004 | 09:25 PM
GVZO6's Avatar
GVZO6
Default whine
same problem mine started whining after 300 miles
To Rearend noise?? Maybe
