MAF resistor?
Old Sep 27, 2004 | 02:23 AM
blndtgr's Avatar
blndtgr
Cruising
Default MAF resistor?
When I bought my '97 I found the previous owner had put some sort of electronic resistor into the un-plugged MAF wire to somehow fool the computer.
Can anyone explain this to me?
Thanks for any help.
Rick
Old Sep 27, 2004 | 07:17 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It tricks the computer to thinking it is always around 40 degrees out, depending on what size resistor was there. The computer changes the A/F, some call it the timming tricker mod.
Old Sep 27, 2004 | 05:44 PM
zukupow's Avatar
zukupow
Well I first read about it in LS1TECH.COM. There is a Post by [B][U]GuitsBoy 07/26/03 under the Power Development>>External Engine,,,Maf Resistor MOD. I did it to my Vette because I bought it in Dallas, TX and then drove it to Arizona where my home sits at 4200 feet of elevation. So I noticed that the car was very lean here. After the MOD the vehicle went from about 24 miles per gallon to about 15 mpg. So I took it out again. I guess the computer adjusted and now I am getting good gas mileage and the car is not lean anymore. Maybe the Vette learned something About increase in HP I do not know, all I know is that the car was working RICH. Also all the pinging the vehicle had went away completely.
To MAF resistor?
