Wheel Bearing Question
Old Sep 27, 2004 | 07:01 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Default Wheel Bearing Question
I had my 98 in for service today and was told I had a bad wheel bearing in one of my front wheels ( 40,000 mi.). What I would like to know is , is this an easily replaceable part or is it a pressed in bearing that would need special equipment to replace?
Old Sep 27, 2004 | 07:43 PM
Patches's Avatar
Patches
The bearing is integral to the hub which you can get a lot cheaper from the auto parts store as several members here have found. It's not that big a job to do yourself.
Basically pull the brake caliper/rotor, speed sensor connector, remove the stabilizer shaft link from the lower control arm and support the lower control arm using a jackstand. Then separate the outer tie rod ball stud from the steering knuckle, separate the lower ball joint stud from the steering knuckle and remove the wheel hub mounting bolts. Finally, remove the hub and bearing assembly from the steering knuckle.
Install the new hub/bearing assembly. Tighten the wheel hub mounting bolts to 130 N·m (96 lb ft). Then reinstall the rest of the components.
Old Sep 27, 2004 | 08:17 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
OEM bearing is a rip and the same as you can get in an auto parts store.
Old Sep 27, 2004 | 08:27 PM
FFIN90's Avatar
FFIN90
Thanks Patches, it doesn't sound like too complicated of a job to try.
Ray
Old Sep 27, 2004 | 11:10 PM
leaftye's Avatar
leaftye
Fairly simple job, but I had trouble breaking the ball joint loose, so I bought the special ball joint Kent-Moore tool shown in the Helms manual. The wheel bearing should run you about $130 from Autozone.
Old Sep 28, 2004 | 04:22 PM
JakeL's Avatar
JakeL
The 2 wheel bearing replacement links here should help:
http://www.jakelatham.com/c5/misc/
Job is a piece o' Cake.
-Jake
Old Sep 28, 2004 | 04:24 PM
jawski's Avatar
jawski
$700-$800 ea from GM
Old Sep 29, 2004 | 01:26 PM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
-Jake
Nice website!!
Old Sep 29, 2004 | 02:19 PM
JakeL's Avatar
JakeL
Thanks!
-Jake
Old Sep 29, 2004 | 08:03 PM
FFIN90's Avatar
FFIN90
-Jake
Thanks Jake, with these instructions and photos I now have no problem with doing this myself and saving BIG $$$$$.
Ray
Old Sep 30, 2004 | 08:29 PM
FFIN90's Avatar
FFIN90
-Jake
Jake, is the torque # for the tie rod bolts used in step #13 the spec, or is that just what you used?
Thanks,
Ray
Old Sep 30, 2004 | 09:48 PM
JakeL's Avatar
JakeL
I think I actually just used German torque specs (Gutentight) on mine. Those docs were actually written by another fellow, so I can't be 100% sure on the specs, since I used the manuals for anything I felt was critical to get the torque right on.
If in doubt, either check the manuals, or give a Chevy dealer a call tomorrow, and they'll straighten you out.
Cheers!
-Jake
Old Oct 3, 2004 | 08:00 PM
FFIN90's Avatar
FFIN90
Thanks again Jake for the instructions.I replaced my bearings today with a mechanic friend of mine and had NO problems at all doing them.
Ray
Old Oct 3, 2004 | 08:36 PM
JakeL's Avatar
JakeL
No problem
-Jake
To Wheel Bearing Question
