Can you patch a run-flat?
Old Sep 29, 2004 | 12:52 PM
'03DreamCatcher's Avatar
'03DreamCatcher
5th Gear
Default Can you patch a run-flat?
My back left Goodyear F1 went flat sometime in the last 72 hours. I haven't driven more than 500 yards on it. Not sure what the puncture is, probably a screw/nail. Is this fixable? If so, is it advisable? It's a daily driver, has about 10K miles on this set. The tire has a plenty of tread, almost all highway miles put on by someone with a lighter foot, so they have lots of life left.
Old Sep 29, 2004 | 12:56 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Yes, but it officially loses it's Z rating. I'd fix it and put it back on.
Old Sep 29, 2004 | 04:17 PM
allanlaw's Avatar
allanlaw
Yes, as long as the hole isn't within an inch of the edge of the tread.
Old Sep 29, 2004 | 04:42 PM
Fast98's Avatar
Fast98
Yes
Old Sep 29, 2004 | 05:36 PM
KingTut's Avatar
KingTut
Default So what good are run flats?
I think this is a real interesting issue - if the tire is not usable after it gets a nail into it. The only thing a run flat offers is to go farther to get you to have it fixed, which if you are going to buy a new tire anyway you can do with a non-run flat.
Just seems odd that run flats are a use only until they go flat once and then shot.
Are the non run flats any easier to patch or just cheaper to replace?
Jim
Old Sep 29, 2004 | 05:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Jim
Jim: nice to see you posting in the forum again.. ltns
run flat goodyear emts can be patched, I had two nails in one tire.. I patched them both and put another 30,000 miles on it.. some runflats can not be patched.. atleast thats what the manufaturer says.. but imo they can all be patched if in the tread area..not sure if all runflats will retain their runflat capability , but the Goodyears will..as long as you didnt run them faster than 55 mph and for more than 200 miles..
Old Sep 29, 2004 | 05:46 PM
vet72899704's Avatar
vet72899704
5th Gear
I've had 2 patched over the years. Both near the middle of the tread and both by Goodyear... and both held fine during regular driving until the tire wore out. Plugging a run flat is NOT recommended. Both times the Goodyear tech lit a small fire of rubber cement on the inside of the tire around the hole for a few seconds to soften the rubber a bit and get a better seal. Worked fine.
Tim
Old Sep 29, 2004 | 06:53 PM
RWhite's Avatar
RWhite
If it is still in its thread depth warranty, Goodyear will fix it free with an inside patch. I had a flat on one of my rears not soon after I bought the car and it has lasted almost 3 years.
Old Sep 29, 2004 | 09:19 PM
Bob Chapman's Avatar
Bob Chapman
Goodyear will allow one patch [not a plug] and still maintain warranty coverage for the speed rating - but only one!
Old Sep 29, 2004 | 11:58 PM
fdxpilot's Avatar
fdxpilot
One of my rears has had a patch for about 8 months with no problem. Took a screw about 1/3 of the way from outside edge. The shop that patched it said the only time it's a problem is if the hole is close to the sidewall.
Old Sep 30, 2004 | 11:41 AM
phear_this_mind's Avatar
phear_this_mind
I just put Khumo Ecsta MX's on my car (stock front size, 295 rear)
THere is a noticeable difference, not as much at launch as I had hoped but stability at speeds of 90 mph+ is quite noticable.
If you buy them on tire rack in the sizes I did then it is $760 shipped. Expect another $70 to have them mounted.
Old Sep 30, 2004 | 11:50 AM
c5chris's Avatar
c5chris
I had done this twice on my rear tires though a Goodyear Tire Center.
Old Oct 26, 2004 | 12:20 PM
'03DreamCatcher
5th Gear
Default Fixed, no problem
Mine ended up being a huge screw/drill bit about 1.5 inches from the side wall. I had the local Chevy Dealership patch it for $23 and have had no problems since. Thanks for the insight!
To Can you patch a run-flat?
