And my dyno reads low?
They are standard, off the shelf 205 AFR heads that have been milled and upgraded to Comp 921 springs.
Obviously, we used all the bolt on tricks, FAST 90 MM manifold, 90 MM throttle body, underdrive pulley etc.
It made 481 RWHP and 434 RWT, on my dyno. Everyone is of the opinion that my dyno reads up to 4% low, but I'm just going with the numbers that my dyno shows. You can extrapolate from there, if you like.
I feel that our upcoming big port AFR head, bigger cam and larger headers could break the 500 mark. (maybe wishful thinking)
Anyway, here's the dyno graph. No BS, no tricks.
Oh, I forgot to add: When I had the heads off, I noticed a nick on the deck. (It probably happened here) I offered the customer a forged shortblock for $2500, installed or I'd install his internals in a new block at no charge. He opted for the forged short block. I only bring this up because this motor was started up, drive exactly four miles and then I tuned and dynoed it. I'd be shocked if it didn't make at LEAST 10 - 15 more HP after it's broken in. The forged parts did absolutely nothing to add power. Quite the opposite, in fact.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Also, great job on the #'s.
-Kam
Good numbers. i'm curious as to the specs of the cam.
I'd just like to see a non CA car do the exact same combo and get the results. Not doubting the product but that would put a lot of minds to rest since so far its been Tony Mamo, LAPD, and now you Andy.
http://forums.corvetteforum.com/showthread.php?t=909339
which really makes me wonder what the heck is going on with the new ls2. most likely programming but what the heck did gm do?
The other 2 Vettes I have seen with the AFRs, one made 440rwhp and one made 420ish rwhp.
I have to warn you, if you keep up this behavior you are going to make me get a divorce.
Knowing that there is someone out there that does what you do, without trying to 'MMS' me to death makes me want to put my new car under the knife. After my experiences in Reseda three years ago, I swore I wouldn't take my car to anyone in L.A. again, or really, anyone for that matter. I really didn't think it would ever happen again, but your actions sure speak highly. Everyone I have talked to does nothing but praise your work, so I would like to congratulate you on doing such a good job.
I'm going to P.M. you about options we have to keep my car in a somewhat easy to make smog configuration.
Cheers!
Or maybe our tuners are better
Or maybe the other specialists suck
What ever ......... bring your car over to Andy's
Good results andy, cam specs. i will try to take a guess at it
228/230 585/591 112 LSA?
The California cars I have seen so far are using a 224 228 grind. Therefore, with a G5x3, all the cars should be over 500rwhp. If everyone can get 480rwhp from that size cam and AFR heads + bolt ons, all the other head people might be out of business.
If you hit around 375+ CFM(Intake) on the 240 Castings, you can count me in as your first customer on that one.
I would agree on the forged parts, they weight more, due to there density.
Kumar, the new norm, seems to be the .575-.585 224-240 cams, even for the stroker. My guess, that is near where a 100% volumetric efficiency is being reached. Just guessing, but the big cube cams that a few of the major vendors have recently put out, have been in that range. Food for thought. Kumar, go to bed..
Andy,
Thanks for taking the time to talk to me yesterday
