I have an apparent slow leak in the evaporator core which is located under the dash. I purchased an 'a/c leak fix' kit which is on its way. Are these leak fix products safe to spray into the system ?? I don't want to make the siuation worse but I figured I'd try this befor tearing the dash out and replacing the evap. core. Any tips are appreciated...
I would definitely verify that the leak is from the evap core first. It is pretty rare that they ever experience this. If it is, however, I wouldn't waste my time with a "stop leak" as these products are designed primarily for stopping leaks around seals, o-rings, etc. by "swelling" the rubber a bit. The evap core is made of aluminum and a stop leak product will have no affect. HTH
Adam, I am in the A/C business and have been doing nothing but Automotive A/C for the past 10 years. I know what products that you are talking about and they have been known to work but only temporarily. I am afraid to tell you this but you are gonna have to take this one on the chin and have it replaced. I would always get a second opinion because alot of so called A/C shops usually don't have someone who is really good and try to fix the problem the right way. The quick sealing kits contain a solution that will stop the leak will also clog the orifice tube, which is a fine filter that regulates the pressure in the A/C system and this tends to get clogged up from the smallest particles so this sealing solution will also clog this causing more problems. Hope this helps!
the mechanic said that the refridgerant 'sniffer' is detecting refridgerant coming from the vents into the passenger compartment. That is how he determined the problem to be an evaporator core leak. Does this sound reasonable to you ? Is that the only possibility ? Thanks again, Adam
I would still have someone check it for you and see if they can put some A/C dye into the system. I think a sniffer is possibly the best device to find a leak but with some small stuff the dye might help. You might just have a bad o-ring or something simple like that, it all depends on how long the A/C Charge will last.
You need to have a dye test done to see specifically where the leak is coming. Do NOT put the leak sealing kit in....more trouble than it is worth and you WILL cause secondary problems as previously described.
i wouldnt trust a sniffer in a blower vent just the air blowing across it will set it off sometimes do not use the sealer have it charged with dye and keep an eye on it as soon as you start to notice the ac weakening take it back to whoever charged it and have them look for dye evaporator cores do fail but there are some other components exposed to the elements that fail more often id hate to see you replace the evaporator core and still have not repaired the leak if it loses its charge quickly the leak should be fairly easy to spot with dye added the only problem being the evap core is completely encased-if its big enough sometimes u will get dye out the drain good luck with it and make sure u fix it the first time dont start replacing parts until its fixed
Check the drain beside/behind the battery for oil stains.
If it is leaking there will be oil stains. If you replace the evaporator
core make sure you replace the accumulator also. This is the
dryer and probably caused the evaporator core to leak.
