Halltech Stinger Installation ???
Old Oct 3, 2004 | 04:41 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default Halltech Stinger Installation ???
I put in the Stinger today in my 01 MN6. It seems to be running fine with no errors (Hurray!).
Two things:
1. There is a hole in the plastic pieve by the throttle body. I do not have a hole in my original one, but there looks like there is a place for a hole. Is the hole suppose to be there or should I tape it close?
2. I noticed at the MAF the connection was not perfect because there was a tab that slide into the old plastic housing. The Halltech Plastic piece did not have a spot for the tab so I had to somehwat put it all together, but I thought the two pieces (the plastic and the MAF) would lock together better...
Of course I could have gotten the wrong plastic piece which I guess would make sense.
Any ideas guys??
Old Oct 3, 2004 | 05:24 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Sounds like you have the 97-00 version of the air bridge. Is the hole on the drivers side of the air bridge just a few inches down from the tb? The early C5s have a sensor that goes in that hole.
Old Oct 3, 2004 | 06:57 PM
Wicked Weasel
Yup. I guess I will call Nate tomorrow and ask him for the correct version.
Well at least I can still drive it.....
Old Oct 3, 2004 | 07:18 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Definitely cover that hole if you intend to drive it in the meantime. Any leaks or holes between the MAF sensor and throttle body can cause lean conditions and codes.
Old Oct 3, 2004 | 11:24 PM
Davesredvette's Avatar
Davesredvette
Welcome to the Stinger club!!!
To Halltech Stinger Installation ???
