Alright...gimme some input
Old Oct 3, 2004 | 08:30 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Alright...gimme some input
Just finally got the car straightened out and now its something new....car idles pretty steady with an occasional "drop" or "miss"...no codes whatsoever so i am thinking it is not a misfire...car seems to "stumble" / "surge" when I give it a little gas and and really hesitates when I put it to the floor....so..................thoughts???
Perhaps a bad coil??
Fuel filter clogged??
Bad injector??
I recently changed plugs and wires (2 weeks) and have checked and rechecked connections......any and all input appreciated.
Old Oct 4, 2004 | 04:09 AM
pewter99's Avatar
pewter99
No one
Old Oct 4, 2004 | 05:38 AM
Black$heep's Avatar
Black$heep
Did you check the spark plug gap before installing them?
Old Oct 4, 2004 | 05:52 AM
pewter99's Avatar
pewter99
yep..I never install plugs without checking and gapping them...never see them come out of the box all the same..
don't know if I mentioned it but problem started 2 days ago...
Old Oct 4, 2004 | 01:45 PM
pewter99's Avatar
pewter99
70 views...1 reply
Old Oct 4, 2004 | 02:13 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Check the O2 sensors and wires. If the sensor wires get damaged, it should throw the low switching voltage code, but mine didn't throw the code until about two weeks after starting its stumbling routine.
Did you change anything? Plug wires?
To Alright...gimme some input
