TTP Stage 3 Equalizer AFR H/C Specials
TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP
TTP Equalizer V.2 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
LS6 Oil Pump
SVO 30lb Injectors
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$4769.95
Options:
LSX 90mm Port Matched Intake Manifold with FAST 90mm Throttle Body - $1465 Installed
Meziere Electric Water Pump with Relay - $600 Installed
Kooks 1 3/4" LTs with 3" x 2 1/2" X-Pipe - $1200 Installed (Add $260 for Cats)
This package just made 481rwhp/417rwtq through a 02 F-Body M6 with LSX 90mm, Mez Electric W/Pump, 4.10 gears, SLP Loudmouth, Kooks 1 3/4" LTs, ORY.
You can give us a call at 973-340-4069 to schedule an appointment.
