Code C1226
Old Oct 5, 2004 | 03:20 PM
BLACK86's Avatar
BLACK86
From: Marblehead, Mass, 2003 Corvette Convertible Black/Black/Black
Default Code C1226
Hello
I have a 1997 Corvette coupe A4. Now that it is cool out in the mornings when I hit a bump in the road I get the code C1226. What is the fix for this?
Thank You
Paul
Old Oct 5, 2004 | 03:43 PM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
i think that is the code for excessive wheel speed variation
Old Oct 6, 2004 | 11:50 AM
BLACK86's Avatar
BLACK86
Default C1226
Ttt
Old Oct 6, 2004 | 12:01 PM
Richin Chicago's Avatar
Richin Chicago
Originally Posted by BLACK86
Hello
Thank You
Paul
It is the right front wheel speed sensor. Look for a loose connection at the wheel. Another failure point is the jumper that connects to the speed sensor. If the connections look good switch the jumpers around on the front and see if you get code C1225 (LF failure) . If you do it is the jumper. The jumper is part number: 10332527
Hey do you ever got to Matty's Sail Loft?
To Code C1226
