Oil Pressure??
Old Oct 5, 2004 | 04:36 PM
Fastbasser's Avatar
Fastbasser
Default Oil Pressure??
What is normal for an LS1 at idle, Oil temp 200 degrees??
Thanks in advance.
Old Oct 5, 2004 | 11:49 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Pressure around 35# at idle. Up to 40-45 at hwy speeds.
Oil temp is relative to how hard you are driving it, in my opinion. After some spirited driving, oil temps of 220+ are not unusal. Mine usually runs around 215 degrees after being thoroughly warmed up on a reasonable hot summer day.
That's one reason why GM recommends Mobile 1 oil in our Corvettes.
Old Oct 6, 2004 | 02:12 AM
mapman's Avatar
mapman
What is normal for an LS1 at idle, Oil temp 200 degrees?? ....
Minimum oil pressure - hot:
6 psig at 1000 rpm
18 psig at 2000 rpm
24 psig at 4000 rpm
Source is the Service Manual.
To Oil Pressure??
