What's the difference between 4L60E and 700R4??
Old 10-06-2004, 09:03 AM
Q8Y
Q8Y's Avatar
Default What's the difference between 4L60E and 700R4??
hi guyz, i want to know What's the difference between 4L60E and 700R4??
the 700R4 auto trans is used with the f-body cars, isn't it?
also what r the gear ratios of them and the manual trans?
in a performance store here in kuwait the salesman said they r the same and i was like this he also said the rebuilding kits r the same
any info guyz, plz help me
im waitin'
Old 10-06-2004, 09:25 AM
SKF engineer
SKF engineer's Avatar
Believe it or not the Transmission cases and gear ratio's are the same for the 700R4 and the 4L60E. The ratios are as follows 1st -3.06 2nd - 1.63 Drive (3rd) - 1.00 Overdrive (4th) - .70 The difference between the two is the 4L60E is computer controled while the 700R4 is cable controlled from the TV cable at the throttle body. There might be some differences with the clutch packs and other stuff, but even different year 700R4's have different clutch packs. I hope that helps a little.
George
C4fetish (06-27-2023)
Old 10-06-2004, 10:32 AM
Q8Y
Q8Y's Avatar
i'm really surprised i thought they were diff from each other . . .
thank u very much 4 the re and the great info ..
take care
Old 10-06-2004, 10:45 AM
t56gen3
t56gen3's Avatar
The 4L60 (and 4L60E) are the replacement (newer, updated version) of the 700R4. If memory serves, the 700R4 stopped rolling into new cars/trucks by around the early 90s (I know my 92 Jimmy had the 4L60, not the 4L60E.) 4L60 is the newer version of the 700R4 and the 4L60E is electronically controlled. Same gearing, supposedly stronger.
Someone else may know the time frames more exact, but that's a ballpark.
Old 10-06-2004, 04:16 PM
Q8Y
Q8Y's Avatar
thanx for the helpful info,, do u guyz know which is the LS1 F-Body auto trans is?
also i want to know which manual trans used in the c5, zo6 and f-bodys?? is it t-56??
Old 10-06-2004, 04:20 PM
t56gen3
t56gen3's Avatar
All should be 4L60E in LT1/LS1 (can't say 100% on the latest years.) T56 in vettes and f-bodies, though they aren't exactly the same.
Old 10-06-2004, 04:23 PM
fdxpilot
fdxpilot's Avatar
They are basically the same tranny. 700R4 was in 3rd gen F-bodies and early C4 vettes. 4L60 (700R4 with new GM tranny designation) was in 93 F-bodies and 91-93vettes. 94 and up F-bodies and vettes had 4L60E electronically controlled tranny. Running change to 4L65E (higher torque capacity) in 04 vettes.
Old 10-07-2004, 12:55 PM
Q8Y
Q8Y's Avatar
thank u guyz 4 the very great info and help,,
what's the difference between the T56 in vettes and f-bodies ??
thanx in advance
Old 10-07-2004, 02:24 PM
kromberg
kromberg's Avatar
thanx in advance
As as the 4L60E, housing shaping and bolt pattern
Keith
Old 10-07-2004, 06:35 PM
Q8Y
Q8Y's Avatar
Thank u Keith for the info
Old 10-07-2004, 06:56 PM
Pug
Pug's Avatar
St. Jude Donor '08
So this means my 04 has the 4L65E?
Old 10-07-2004, 07:51 PM
ndirishr1
ndirishr1's Avatar
Can't tell you the diff but I can tell you the 700R4 should have been called 700R4POS. Had it in an '84 Chevy van. Well actually had 4 of them as they didn't last long. Had it in my '84 Vette too. Well only 2 in the Vette so I guess I was lucky. They had trouble shifting in and out of over drive and would beat themselves to death.
Old 10-08-2004, 07:03 AM
Q8Y
Q8Y's Avatar
thanx 4 the re guyz..
To What's the difference between 4L60E and 700R4??
Quick Reply: What's the difference between 4L60E and 700R4??
