FLP Headers - Rusting After 4K Miles - WTF?!?
I started the car two weeks ago and when I looked behind the car there were a lot of rusted metal flakes behind the exhaust tips. At first I thought it was the cats because the inside of the FLP's are supposed to be coated, and the rest of my system is stainless steel. After showing the material that came out of the exhaust to some local experts, we figured out what had happened.
We unbolted the X-pipe to cat-back connection and looked inside the X-pipe. Sure enough, it was rusted like crazy. I am worried now that my header pipes will plug my cats up with rust flakes. I know the car won't run if this happens.
Now you might be thinking, what did FLP say about this. I wish I knew. They seem not to want to return my tuner's phone messages to discuss an appropriate course of action. I bet if I called to place an order, they would call back right away. I only have about 4 or 5 thousand miles on the FLP system and as far as I am concerned, it is junk. I paid a lot for the system and to have it installed, so I hope FLP steps up and does the right thing.
Has anyone else here had a similar experience. If so, what remedy was offered by FLP?
I recommend that you guys with FLP's unbolt one side of your cat-back and check the condition of the inside of your X-pipe. Then, check your header pipes / merge collector.
I wish I had taken some pictures of the rust flakes so you could see the size and quantity.
Its why I went with 304 stainless as opposed to "coated" headers. Most of the headers which come with Jet hot or other coatings are mild steel beneath the coatings. If there is a breech in the coating a nick, chip or scratch, when the mild steel underneath starts to corrode it can be tough to manage.
Hope you get it taken care of and good luck.
... Most products have some kinda warrenty for problems like this. However, generally it's just for parts. I think one is better off to get the Stainless Steel and spend their time driving their Vette instead of redoing work.
Maybe you could also call the people over at Jet-Hot and talk to them about this.Jet-Hot coatings
You should get on the phone yourself and talk to FLP. Good luck.
http://forums.corvetteforum.com/show...lp+heADER+RUST
"I have a little issue with my DS header..............this is NOT FROM THE AC discharge and you can see the scratch marks I touched up prior to firing up after the install. No rust in the scratch marks, but below
"The PS is fine"
"Usually inproper prep for the coating/thin coating application is the reason for this.
The vendor I bought these from is looking into it.....less than 1 year on an EDD.
I will sand & put some hi-temp on just like the scratches
I got them from LAPD.......they got with FLP............I went to FLP's shop in Dec 03' while in town and talked to Mitch & Chuck about them, these pictures and the e-mails I had sent them. They were nice enough to show me around the shop & talk shop but.............no resolution or call as of today. They are Airborne coated...........and not as big a deal as a leak or broken collector tab but damn the DS looks like crap and its deep rust!
Good luck, call FLP/vendor you got them from
