suspension
Old Oct 7, 2004 | 02:43 AM
mlumb's Avatar
mlumb
Default suspension
hello everyone,new owner here from the UK.
im looking to lower my c5 a little on the standard suspension but not sure exactly how to do it.
ive read the threads on adjusting the bolts but could do with a bit more info please.
thanks.
mike.
Old Oct 7, 2004 | 02:50 AM
hoosierhic's Avatar
hoosierhic
thanks.
mike.
Hello Mike Welcome to the forum. The adjusments are fairly simple. The fronts are the toughest and I found you need to relieve some pressure from the spring by inserting a block or jack between the aframe and sring to allow the bolt to turn freely but to do these turn the bolt counter clockwise to lengthen it above the a frame. The rears Just loosen the Nut to leave 3 threads at the top of the bolts. Thats all there is to it,
Old Oct 7, 2004 | 05:07 AM
ditty22's Avatar
ditty22
Do a search and u will find crap loads of how to info with helpfull pics. seach thing is at the top of the page in a red task bar. hope this helps
Old Oct 7, 2004 | 11:01 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Hello, and welcome!
Not sure if these are the threads you've read, but maybe these will help:
http://www.crossedflags.com/nuke/htm...=article&sid=7
http://www.c5forum.com/diy/lowering.php
Old Oct 7, 2004 | 11:58 AM
mlumb's Avatar
mlumb
thanks very much.just what i needed.
mike.
To suspension
