Road Race Autocross??
You WILL get hooked on this, its an absolute blast!
have fun
J
http://forums.corvetteforum.com/forumdisplay.php?f=23
Tracking a car (typically Driver's Education events) run 20 minutes on a continuous course, is faster, not as darty (started to use the word "technical" but didn't want to get
), from turn to turn, and puts a lot more heat into the car. Engine, brakes, tranny, you name it.Both are an absolute blast to get into.
Both will also wear out brakes, tires, and drivers!
Welcome to the club. Stop by the Autocross section, there's a sticky post that's got a ton of great info.
Have a good one,
Mike
http://www.pfyc.com/store/merchant.m...ry_Code=VTSUSP
Picture this scenario - you've run a number of laps and your fluid is good and hot. You go into a braking zone a bit too hot and activate ABS. Your fluid temp is OK for the Motul, but too high for the stock crap. ABS unit fires, discharging the crap fluid into the system. Stock fluid boils, air in the lines, well you know the rest....
