Help, what is a P-1441?
Old Oct 7, 2004 | 07:46 PM
ndirishr1's Avatar
ndirishr1
Default Help, what is a P-1441?
My '01 6-spd check engine light came on and I found it had thrown error code P-1441. I cleared it, took it for a short drive, checked and found it had thrown it again. Can anyone tell me what this code means or where I can research it? Figures, I'm about 2 days out of warranty....
Thanks!
Old Oct 7, 2004 | 08:31 PM
Greg_E's Avatar
Greg_E
P1441 EVAP System Flow During Non-Purge. (Taken from '99 service manual)
The PCM detected a vacuum in the EVAP system when purge was not commanded.
Things to check:
EVAP purge solenoid valve and line. Check for carbon contamination of the valve and line. check for kinked or damaged vacuum lines.
Hope that helps.
Old Oct 7, 2004 | 08:49 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
You'll have to take it to the dealership and have them do a smoke test on it. They can clear the code and if there good they'll do it for free
To Help, what is a P-1441?
