A-Pillar Install Instructions
Old Oct 9, 2004 | 06:13 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default A-Pillar Install Instructions
Does anyone have a good link to install instructions for an autometer 2002 gauge pillar? I would love a link so that I can do the install tonight. The search only return 9 hits for the word "pillar" since the 7/2004 downgrade of software.
Thanks in advance to anyone who can help me out here.
Old Oct 9, 2004 | 06:30 PM
BQuicksilver
http://forums.corvetteforum.com/zerothread?id=756211
Supposedy this now dead link has some info I could use?
Old Oct 9, 2004 | 08:03 PM
JoeyG's Avatar
JoeyG
Well heres how I did mine. I'm refering to the dual gauge pod.
Remove the factory a-pillar, just held to the pillar by 4 spring clips, grab and pull. Now take you new gauge pod and slip it over the factory piece. Once everythig is lined up, I marked and drilled holes for the locator/push pins. I just positioned one at the top of the pilar, and the rest just got evenly located down the front and backsides of the pillar pod assembly. When I mounted mine up, the autometer piece had a little bit of slop in the sides, so I used 3M autobody tape (red backing) to make both pieces mate perfectly. Haven't had a problem yet.
Old Oct 9, 2004 | 08:05 PM
BQuicksilver
Thanks Man, just in time. I was out the door to the saturday night mod shop.
Old Oct 9, 2004 | 08:22 PM
JoeyG's Avatar
JoeyG
Hope it goes smooth
Old Oct 10, 2004 | 01:21 AM
T_Vert's Avatar
T_Vert
use 3m doublesided tape so you dont have to drill yoru stock pillar. i did and it held fine.
dave
To A-Pillar Install Instructions
