Does dirt getting past high flow filter really hurt anything?
(http://forums.corvetteforum.com/showthread.php?t=911828) . While this thread raised the question of just how much of a measurable performance improvement high flow filters really make (a subject still open to some debate, apparently), it also touched on the subject of the actual filtering capacity of high flow filters. While some interesting data was shown as to the amount of "dirt" which got past different filters (http://www.bobistheoilguy.com/airfilter/airtest1.htm) there was little information submitted to attest to the real world effect on an engine's longevity using a high flow air filter, other than one person stating that after running for one year with no air filter of any kind, their dyno numbers didn't change. Judging from the pictures of the "dirt" collected on the secondary paper filter which was mounted downstream of the high performance filter, I would suspect that these are very fine particles, and am wondering if they are abrasive enough to present significant wear issues.
So here's the question: does the amount of "dirt" which gets past a high performance air filter really have any effect on ring wear or valve stem/seat wear, or any other significant detrimental effect on an engine?
I guess the more important question might be this: has anyone had a Stinger, Blackwing, K&N or whatever for several years experienced any premature upper or lower engine wear?
My advice to anyone running any type of aftermarket air filter and/or intake system, is to get an oil analysis done to make sure you're not hurting your engine. This way you can correct the problem before it becomes a much costlier one. Better to spend $20 on an oil analysis now as opposed to $3000 for an engine rebuild a couple of years later.
